Deletes a default gateway from the routing table.
| ipv6Gateway | Specifies a VLAN gateway IPv6 address. |
| ipv6ScopedGateway | Specifies a scoped gateway. |
| vr_name | Specifies the VR or VRF from which the route is deleted. |
If no metric is specified, the default metric of 1 is used. If you do not specify a VR or VRF, the current VR context is used.
Default routes are used when the router has no other dynamic or static route to the requested destination. A default gateway must be located on a configured IPv6 interface.
The following example deletes a default route from the switch:
configure iproute delete default 2001:db8::1234:5678
Support for IPv6 was added in ExtremeXOS 11.2.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
